The little plastic clips that hold the plastic rocker panel cover on.
I have checked all the parts stores, no luck on line, can't get the old ones off without breaking them.
Does anyone have a source for these little ##@$%%!!s ?
Thankx 4 your reply, Sunfiretun3r. I hadn't tried gmpartsdirect.com. No luck so far, they have a part number on them, but I don't have one with me. I'll try that later.
Gmpartsdirect.com looks like a good source, I found a rear quarter-panel for my convertable, but it ain't cheep. Makes a little Bondo seem not so bad after all.
Sure if you can't find them snap a pic for me and I'll see if I can get some from my work. If I can, I'll ship them flat rate.
Hello!! What's this? ... If I lay belly down in the mud, I can see little access holes, with rubber grommets in them. I can just reach in and compress the back of the clip, with a pair of ''hook-nosed, needle-nosed pliers. I can re-use the old ones ... the day is saved, etc.
I am not believing that I am the only one that ever tore one of these things up, and tried to replace it. Somebody is not 'fessing up.
the passenger side one on my vert is screwed up but I have been too lazy to try and fix it lol
Hey, Zs Z , I'd say that these things are not too hard. But I haven't done it yet. For some reason they didn't provide access holes for every clip, but I can raid the junkyard for plenty more. Right now I'm looking for the right pliers(long enough) to reach up in there. I was lucky in that I found the plastic rocker cover in the right color, so I don't have to paint it. Good Luck man.
