Fog light wiring - Exterior Forum
Fog light wiring
Sunday, May 30, 2010 5:40 PM
hey, im thinking about putting fog lights on my sunfire, just some small ones int he front bumper, what should i hook it up to, DRL's? or high beams. or maybe a seperate control switch?
Re: Fog light wiring
Sunday, May 30, 2010 7:42 PM
I would use a separate switch... You will need to use a relay for them too. The way that I have it wired is the trigger wire for the relay comes off the running light wire with a toggle switch between. That way if I forget to turn my fogs off they will turn off with the main lights.
Sunday, May 30, 2010 7:55 PM
thats pretty smart, ill probably do that.
Sunday, May 30, 2010 8:00 PM
I had mine hooked up with a relay off the running lights as well. It works perfect. If you want to be able to switch them off, do as Jeffrey suggests. I personally never turn them off, and like having just running lights and fogs on at dusk, so I didn't bother adding the extra switch. It's personal choice, but the relay is a must.
