Simple question, i know.
But will an HID Kit for 9007 bulbs fit my 03 stock headlights? I'm almost positive 9007 is the stock size. Also, i'm not familiar with how HID kits work. Don they require any modification of the headlight housing? Is it basically an amplifier? Also, what type of bulb will i need to be running with it?
Thanks for the help!
They install just like a stock bulb
9007 will work for 03.
You will need to mount a ballast, and if you do end up going hid buy a relay and hook it up using that, otherwise warming the bulbs and ballast up is a pain as the stock connections baaaaarely have enough juice to get them going.
It will tell you to cut a hole in your plastic cover on the back and wire through that, (the big cup shaped thing) don't bother, as the connections take up too much room in the cover and you won't be able to get it closed anyways.
You will only have your first moisture seal, but it should be okay. I've been running mine like that through the winter and I have no moisture in my headlights.
And do a projector retrofit! www.retro-solutions.com
yeah make sure that you buy a relay kit for it. Depending on how much room you have to mount ballasts you may want to buy the slim ballasts instead of the "norm"... I'm just using the norm but my bay is stock so there is enough room for mounting.
Also try not to mount them anywhere on the inside wall of the bay... i burnt up a ballast doing that. Now they're both residing underneath their respectable headlight and everything is working fine
HID's are so much nicer at night that I do not think I'll will ever go without them again
p.s. point them down a little bit. People don't appreciate bright lights in their eyes
And now you are reading my signature...great
My 2004 Sunburst Orange Sedan -
http://www.j-body.org/forums/read.php?f=47&i=54063&t=54063
input is highly appreciated!
ddmtuning.com is a perfect place to get them they offer the kit for around 75 will a life time warranty
does anyone have pictures of hid's in there 03-05 cavi? does anyone have them in the fogs?
thanks
sorry to bring back a week old thread
i would take one today but one of ballasts conviently decided to go out this morning.... So im working on that one. I think i have a few on my computer; ill look tonight.
This is the only one that I can find atm. It's not the greatest.. srry haha If you are still wanting pics after i get my ballast replaced, i will take some new ones and send them to wherever you want... let me know
lol its ok man, if you can get one from at night that would be great.. are those 8000k?
Here are mine. I have projectors in the headlights 4300K and 3000K in the fogs.
Drivers side is 3000K hids and passengers side is nokya yellow halogen
All HIDs
i just bought some 8000K 55w ones for ddmtuning they are on their way
http://memimage.cardomain.com/ride_images/3/3450/1901/33623450078_medium.jpg
My 8000k's
i got a bixeon hid kit and it keeps staying on the highs anyone know how to get rid of that ?
kyle dresher wrote:i got a bixeon hid kit and it keeps staying on the highs anyone know how to get rid of that ?
same thing here dont know whats wrong with it yet.
Sig thanks to bxmobkrazey on gmscf.com
do u have ur drl diabled?
well from all the hids i got for every car i drive i found out its a waste to go over 5,000k you can't see @!#$
