Projector headlights... - Exterior Forum
Saturday, July 11, 2009 7:02 PM
I see alot of you have custom projector headlights. I just built a set of my own and they look very similar to the ones that John is building. but I have come across a problem with mine. I cant get the high beams to click on when I click the lever, so all I have are low beams. Can anybody possibly help me with this problem? It would be greatly appreciated! Thanks, Dave
Re: Projector headlights...
Saturday, July 11, 2009 7:42 PM
what projector units are you using, are they bixenon or halogen? using relays? you really didnt give any info.
Saturday, July 11, 2009 9:31 PM
If you're using a relay harness with a bulb socket adaptor, try swapping the order of the wires in the socket adaptor until they work correctly.
www.sickhids.com
Sunday, July 12, 2009 7:02 AM
a little more info would help diagnose the problem.
Sunday, July 12, 2009 12:56 PM
Ok here are some pics of the projectors when I got them in the box, and a pic of them wired into my car. I switched the wiring in the harness like the instruction book said for 9007 lights and the high beams still wont work. If I switch the high beam wire with the lo beam wire then I just have high beam.
Sunday, July 12, 2009 1:12 PM
did it come with a relay harness cause my set has a relay for the high/low beams and i had to also switch the outer wires in the blue plug so my lows were in low postion and the highs were highs.
Sunday, July 12, 2009 3:23 PM
Yeah, you have to keep changing the order of the 3 wires in the blue socket adaptor (not just 2 of them) until they operate correctly. Trust me, the problem is the order of those 3 wires (blue, white, red). Keep trying until they work right (pay no attention to what you believe is Lo & Hi wire, just keep changing. You are usually dealing with GROUND loops for Hi & Lo, so your COMMON wire may be GROUND or it may be 12vdc (+). You can't try to figure out which is (+) HI & which is (+) Lo.
www.sickhids.com
Edited 2 time(s). Last edited Sunday, July 12, 2009 3:27 PM
Sunday, July 12, 2009 4:07 PM
looks like you don't have an isolator on that ballast.....could be the problem.
Wrap them in electrical tape..
Sunday, July 12, 2009 6:29 PM
Thanks for the info guys, I got them workin I broke out the Haynes repair book and looked at the headlight wiring section. the problem was what bluedriftcavy(a.k.a. wayne) and Sick 99 GT were sayin. Now I have hi and low beam. thanks all for helping to point me back to what I should have checked first.
Sunday, July 12, 2009 6:33 PM
Cool.
Do you have any pics of the acual headlights? I ordered the same kit last week. Hopefully I wont have this same issue
Edited 1 time(s). Last edited Sunday, July 12, 2009 6:44 PM
Sunday, July 12, 2009 6:49 PM
Glad I could help.
www.sickhids.com
