ugh paint the car - Exterior Forum
ugh paint the car
Thursday, July 09, 2009 9:30 PM
ok as most of you know, my car has bad bad bad sunspots and i have decided to get rid of them before i do anything else to my car, now i took it to a paint shop and they want about 1500.00 to do the same color, now i feel that i have enough skill to paint the car my self.
i know the basics
sand
sand
primer
(sand again? o.O)
paint
wet sand
clear coat
i need specifics such as what type of paint, what grit sand paper, how do you wet sand *never done it* i have a gun, should i spray primer and clear from that gun or just rattle can it, im not going after show winning quality, but im tired of sun spots and want to get rid of them untill i can take her up to a shop and have a pro paint job done
any help would be amazing!
now pix time
[IMG]h[IMG]http://i7.photobucket.com/albums/y283/crazysword/l_fa75d0cfed604bcdab0cdef8008fcd-1.jpg
[/IMG]ttp://i7.photobucket.com/albums/y283/crazysword/l_ef2659271a6341c8a1ac11fccaf6c0b9.jpg[/IMG]
Re: ugh paint the car
Friday, July 10, 2009 9:19 AM
*PSHHH* READY FOR TAKEOFF!
In all seriousness, you're better off letting Maaco do it.
*2000 Cavalier sedan*
Friday, July 10, 2009 9:44 AM
Ummmm yea,
About the wing..............Get rid of it.
Friday, July 10, 2009 10:03 AM
You don't wetsand the base, you wetsand the clear if it's not flat. Then you will hafta wheel it after.
Proper process is:
Sand all down with 320
Fill low spots, sand again with 320
Spray with filler primer
Spray a guide coat (light cover of black spray paint)
Sand with 400-600 dependng on how many flaws
Spray another guide coat and repeat untill satisfied with no dings/flat spots
Spray with primer sealer with the correct value shade
Spray base coat
Spray clear
Wetsand/wheel if needed
Now for your gun, the quality of the paint job depends highly on this. Usually you want to used a different gun for primer and paint/clear. Primer will need a 1.5-1.7 tip, paint and clear you want 1.5-1.3 tip.
Good luck if your not to worried about the outcome give it a shot, it takes some practice to get it down.
Member of J-body of Michigan.
Friday, July 10, 2009 11:20 AM
Mike (96RedCav) wrote:Ummmm yea,
Uh ^^^^^^^^^^^^^^^ yeah. that.
Friday, July 10, 2009 11:45 AM
ACav2Envy wrote:You don't wetsand the base, you wetsand the clear if it's not flat. Then you will hafta wheel it after.
Proper process is:
Spray base coat
Spray clear
ill agree 100% with him. that's exactly how it should be done. as for the 1500$ that's a pretty damn good deal. our shop would charge around 3000$ for something like that. and i will warn you now if you try it yourself and you've never sprayed a metallic (highly doubt you have) then i guarantee it will be "tiger striped" which is exactly what it sounds like. the metallic will bunch up in spots from improper spraying and it will totally screw u over and will look WAY worse than the sun spots. just pay the 1500 and make sure its done right.
Friday, July 10, 2009 12:17 PM
if your just going to have it painted at a shop later than your best bet is the $50 paint job... the $50 paint job is the same sanding and prime work as a spray job. then you use rustoleum gloss exterior finish(ONLY RUSTOLEUM). about 1-2 gallons in the color of your choise. itll take 5-6 coats applied with a fine roller, you have to wet sand the entire car after every coat to get rid of the orange peel and make the coats even if you had some high spots from rolling the paint on. and theres no need to clear, the gloss in the paint is plenty. so once all the coats are on and the wet sanding is done, let it sit for 12-24hrs then go at it with a buffer and a small amount of compound and itll shine like a mirror.
ive seen mutipule vehicles in pics and in person with the $50 paint job and 90% of the time its way better than a macco spray, spraycan job, and even some factory spray jobs. i can go dig up some old threads with pics. try searching about it, lots of info. there was a beretta on here awhile back they did in white with the $50 job and it looked way better than most hack spray jobs. any dumbass with a compessor and gun can paint something......but will it look good? most likely no. with the $50 job theres no way to F it up, just wet sand between every coat and do a good job on body perp.
Saturday, July 11, 2009 5:50 PM
http://www.j-body.org/forums/read.php?f=7&i=374231&t=374231
my $50 paint job I posted about last month. I'm waiting for an excuse to do it to one of the other 2 cars now - or I'll have to buy a 4th car to paint.. lol
I still haven't done the final rubout and wax on it - gonna do something on the hood to match the lower panels. The mockup looked great, so i just need to get off my lazy *ss and do it
best winter beater in town!!
Beauty is in the eye of the beer holder.
Saturday, July 11, 2009 6:34 PM
before you do anything to your car do yourself a favor and get rid of that spoiler
!pıɐן ʇǝƃ oʇ pǝǝu noʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
-_-_-_-JCO EastSiderZ-_-_-_-
