Sunfire sedan trunk badge removal? - Exterior Forum
Saturday, July 11, 2009 1:35 PM
How do I remove the part that says sunfire in red on the trunk? Is it just held on by adhesive? Holes of any sort? Any tips on how to remove it would be greatly appreciated
Re: Sunfire sedan trunk badge removal?
Saturday, July 11, 2009 1:36 PM
woops I mean how do I remove the part that says "pontiac"
Saturday, July 11, 2009 1:57 PM
going to go ahead and say it adhesive. Seen many of them with that part of it gone.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Saturday, July 11, 2009 2:05 PM
You should swap to a shaved cav trunk. That would be the cleanest I think.
~Jeff
Sunday, July 12, 2009 11:22 AM
God I miss the Sedan (the one in the picture) .
Yep, it's just held on with double sided tape. Just pull the letters off with your fingers and than use some WD 40 to get rid of the leftover adhesive.
Sunday, July 12, 2009 11:56 AM
i vote cav trunk!
WiGM-Tuners member.
Sunday, July 12, 2009 10:11 PM
This is my actual car, taking better pictures tomorrow after work since its all cleaned up now.
Will be removing the pontiac emblem on tuesday
Sunday, July 12, 2009 10:15 PM
^remove door badging should be on the list as well!
WiGM-Tuners member.
Sunday, July 12, 2009 10:26 PM
02_redbadged wrote:^remove door badging should be on the list as well!
And you're sure its only adhesive? No holes?
Sunday, July 12, 2009 10:27 PM
Adding heat very carefully can also help when removing badges, and also to help get underneath them fishing line can help.
Sunday, July 12, 2009 11:43 PM
100% positive its only adhesive! so are your door moldings!
listen to punkerest! fishing string is your friend! won't hurt your paint or your fingers!
WiGM-Tuners member.
Monday, July 13, 2009 6:21 PM
Josh Barnhart wrote:And you're sure its only adhesive? No holes?
02 redbadged wrote:100% positive its only adhesive! so are your door moldings!
Yep, it's just adhesive! Here are a couple pictures of my old Sedan with the moldings and badges removed:
Fishing line, a hair dryer and WD 40 are your best friends when removing badges and/or moldings from your Sunfire. Also, here's a great how to for removing them. It's a major PITA and your fingers will hurt like hell for a few days, but it's all worth it in the end .
Also, I highly suggest doing a Cavalier trunk swap. It looks so much cleaner IMO:
Thursday, July 16, 2009 1:49 AM
J to envy, I've drooled over your sunfire for quite sometime on car domain, wasn't even thinking when I seen the name here lol. Thanks for the advice, your car was alot of inspiration so far. You nailed it on the head when you said your fingers will hurt, they sure did. As for the side moldings, there are not holes behind those either?? I'd love to remove those, although they have saved my car from quite a few dents from other peoples cars.
Thursday, July 16, 2009 1:52 AM
no edit button:
Also my rear bumper is in need of a respray after backing up into multiple items, I'm considering shaving the sunfire out of the bumper for a flush look.
Are there any instructions for how to remove the rear window stoppers, I love the look of the windows being rolled all the way down. Not to mention the complaints I get from rear passengers when they realize they're far old enough to handle the responsibility of a rear window being all the way open lol.
Thursday, July 16, 2009 7:24 AM
For the window
Hope that is what you wanted
Thursday, July 16, 2009 10:32 AM
Gardenmega wrote:For the window
Sweet! Thanks! JBO has so much information, I just have trouble finding it all.
Thursday, July 16, 2009 1:36 PM
Lol i know, i just remembered seeing the how to and was like ill post it for you
Thursday, July 16, 2009 2:02 PM
Josh Barnhart wrote:J to envy, I've drooled over your sunfire for quite sometime on car domain, wasn't even thinking when I seen the name here lol. Thanks for the advice, your car was alot of inspiration so far. You nailed it on the head when you said your fingers will hurt, they sure did. As for the side moldings, there are not holes behind those either?? I'd love to remove those, although they have saved my car from quite a few dents from other peoples cars.
Thanks for the kind words. I'm glad my Sedan has inspired you. I miss it every day .
If you decide to remove the side moldings, your fingers will really hurt, but like I said, it's all worth it in the end. I guarantee you there are no holes behind the side moldings. It's held on with two strips of double sided tape, one along the top and one along the bottom.
Josh Barnhart wrote:no edit button:
Removing the rear window stoppers is one of the best and easiest things you can do to your Sedan. It looks so much better with the windows all the way down.
In case you haven't read through it yet, here are some other free and easy mods you can do to your Sedan.
If you ever have any more questions, don't hesitate to get in touch with me Josh.
Friday, July 17, 2009 3:09 PM
Removed my window stoppers, best thing I have done so far, not to mention the easiest. I'm considering doing the door moldings, I need to start taking pictures before I go any further though. Very informational free mods page! Only thing I haven't done so far is the DRL, and I'm not sure if i will.
Friday, July 17, 2009 5:11 PM
Just wear some thickish gloves and wrap the lines around your fingers so it wont cut into your fingers.
Friday, July 17, 2009 6:11 PM
Josh Barnhart wrote:Removed my window stoppers, best thing I have done so far, not to mention the easiest. I'm considering doing the door moldings, I need to start taking pictures before I go any further though. Very informational free mods page! Only thing I haven't done so far is the DRL, and I'm not sure if i will.
Awesome! Glad to hear you got rid of those window stoppers! I highly recommend disabling the DRLs because it looks so much nicer cruising with just the parking lights on . Just my $.02 though. Definitely start taking pictures. I want to see some before and after pictures.
TheSundownFire wrote:Just wear some thickish gloves and wrap the lines around your fingers so it wont cut into your fingers.
That's a great suggestion, although your fingers won't really hurt from using the fishing line, they will hurt from removing the adhesive which really can't be done effectively while wearing gloves.
Friday, July 17, 2009 9:31 PM
I just scrubbed with WD40 and it came off. My fingers hurt from the line digging into them.
Monday, July 20, 2009 1:14 AM
Took alot of pictures today, heres a teaser i resized, will resize the rest tomorrow.
Monday, July 20, 2009 1:55 AM
2 more, i'm off to bed now lol more tomorrow
Monday, July 20, 2009 3:43 PM
Looking good Josh! I can't wait to see more!
