Does anybody know the dimensions, height, width and depth, of an 05+ rear bumper cover?. I really like the new style bumper and was trying to figure out how hard it would be to retrofit on an 01 Z.
it fits right on.....just need to remove the filler panels under the tail lights.
John Benham wrote:it fits right on.....just need to remove the filler panels under the tail lights.
Maybe. The bumper mounts up but I had to modify a bit.. I had a knock off from bumpers.com so i'm not sure if there's a difference, but I had to use sheet metal screws under the tail light to secure the 03+ bumpers filler panels. Also, I believe there might be a bracket on the wheel well on 03+ cars, but I had a gap where it mounts so I used a rubber hose to fill the space before I drove a screw through. I want to say somebody confirmed this when I did the mod years ago.
Convert 00+ headlights to 95-99
cavGTP (1dersk8) wrote:John Benham wrote:it fits right on.....just need to remove the filler panels under the tail lights.
The 03+ bumpers have a plastic piece that it bolts to that you then bolt to the car. This will take care of the filler pieces, it will proide a piece to screw into. And if you did have this piece and still had the problem, oops nvm
