I guess im an idiot when it comes to removing this, because i can't seem to get it! I swapped out my trunk for one at the yard because of defects on mine and now i cant seem to get the lock out of the old one. I've been tinkering with it for about an hour, but still no luck. anybody know how to properly do it? If this is in the wrong section then my bad!
i take it you mean sunfire?....u gotta knock the center of each rivet out, then drill out the rivets then re-bolt it or rivet the one u want to use in
Edited 1 time(s). Last edited Friday, January 23, 2009 5:07 PM
^^^^^ huh? on mine there was a little clip holding it to the inside of the trunk. I swapped my lock when I did the cavalier trunk swap, there should be a little clip on the inside of the trunk, pry it upwards, and the lock pushes out. on sunfires, you need to take off the speed nuts that hold the taillight bezel to the trunk. Hope this helps, but don't quote me as some could be different from others.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
yeah i figured it out, i just drilled out the rivets and pulled the clip on the back out. Thanks for the replies guys.
974drfire wrote:^^^^^ huh? on mine there was a little clip holding it to the inside of the trunk. I swapped my lock when I did the cavalier trunk swap, there should be a little clip on the inside of the trunk, pry it upwards, and the lock pushes out. on sunfires, you need to take off the speed nuts that hold the taillight bezel to the trunk. Hope this helps, but don't quote me as some could be different from others.
you = 4dr ....4dr = pretty much a cav... cav = different
This only applies to Sunfire Sedans. The Coupes need to be removed just how Gary said.
haha beat you to the post
lol
Yeah, I figured they'd be different as I have little experience with sunfire coupes, mostly cavs and my 4 door sunfire.
Glad you figured it out, though.
yup cavalier coupes and sedans are exact same trunks unlike sunfire sedans n coupes
azvcav ( the DROPPED top) wrote:yup cavalier coupes and sedans are exact same trunks unlike sunfire sedans n coupes
Cavalier Coupes, Cavalier Sedans and Sunfire Sedans are the same. The only odd ones out are the Sunfire Coupes.
azncav ( the DROPPED top) wrote:yup cavalier coupes and sedans are exact same trunks unlike sunfire sedans n coupes
Right, I rock a shaved sedan lid on my 96 coupe. Didn't want to molest my perfect stock lid
