hid drl disable + malibu mod... - Exterior Forum
Sunday, December 14, 2008 5:29 PM
so, i come here today, asking advice from the jbo electrical gods.
i've done the malibu hi/low beam mod (activate a relay off of the high beams to turn on the low beams) and an h.i.d. kit. i followed the instructions in the sticky for disabling the drls (cut the small blue wire on the cluster harness), but all that managed to do was disconnect my e-brake switch altogether. whenever i go to even put the car in "on" without the headlights on, i get a both low and high beams flashing on both sides and the drl indicator lamp flashing. so thats where i stand. i have the day off tomorrow and will try to sort this out.
Re: hid drl disable + malibu mod...
Sunday, December 14, 2008 5:35 PM
About the only advice i could give you probably wont work. I did not modify an wires in either of my cars. I used a Tech II to disable the DRL's.
Sunday, December 14, 2008 5:37 PM
i want one of those. but alas, the two dealers in my area would not only charge $120 for labor (cost of one hour), but i HIGHLY doubt they'd know what they were looking for.
Sunday, December 14, 2008 8:45 PM
you dont CUT the wire, you ground it....
Sunday, December 14, 2008 8:46 PM
first post in the sticky say to but the small blue wire and tape up both ends...
Sunday, December 14, 2008 8:47 PM
upps....
forgot to explain....
to explain, the computer is clicking them on and off, looking for a ground to show that the headlights are on. thus disabling the drls. i learned this by when i installed my stereo,used the same ground location, and some how my disable wire came un-attached. well sure enough, every time i cut the car on, the headlights flash 4-5 times, and then the "maintenance" light comes on.
Sunday, December 14, 2008 8:52 PM
but then wouldn't the brake light in the cluster be on constantly? because it never comes on now whether the ebrake is up or not...
What year is your car? on my 02 the brake sensor wire is also blue, but a light blue. I think you cut the wrong wire.
Sunday, December 14, 2008 8:53 PM
96. i cut the one it showed in the sticky.
Sunday, December 14, 2008 8:57 PM
Brian Anderson {1999-Z24-4spd} wrote:This is a fully conclusive write up for the 3rd generation j-body DRL Disable. The 95-99 trick was found by Mr. John Lenko. HUGE THANKS to some members that wish to remain nameless, and CaviFreak for getting the 00+ one done Thanks to Cavi sedan ls (justin u) and Phewes because i stole their pictures.
This also has the tricks for the 96-99 and maybe other year J-Bodies to make the fog lights stay on with high beams. Thanks to MantaZ and Team Forward Motion.
For DRL Disable on 1995, 1996, 1997, 1998, 1999 J-Bodies
1. Remove you Topper Pad
2. Remove the Bezel
3. Locate the Harness and pull back / cut the electrical tape
4b. For 96-99 you cut the smaller blue wire. (Cavalier = pin B8 Sunfire = pin B7)
5. Tape each end up
6. Pull back some electrical tape...and/or re-tape it up
7. Reconnect it
8. Put your dash back together
NO MORE DRL'S!
(another way is to get ahold of a tec2)
is how i did it.
Sunday, December 14, 2008 10:41 PM
*** Note to all, make sure when you cut it that you leave enough slack on both ends so some day if you go to reconnect it, its easier to splice a wire back in.
Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Monday, December 15, 2008 7:12 AM
I have a funny feeling you cut the wrong wire man.
Satch Timeline Progress Thread
JGM T-SHIRTS!!!!
Thursday, December 18, 2008 12:02 AM
I SATCHMOE YOU!!!! wrote:I have a funny feeling you cut the wrong wire man.
x2
Thursday, December 18, 2008 5:19 PM
there are two blue wires, even though it clearly explains how to do it, it's not uncommon that people on here accidently cut the wrong one. one is for the DRL's and the other is for E-brake. I'd take it back apart to see if maybe you cut the wrong one.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
Thursday, December 18, 2008 5:47 PM
agreed. i also had the SAME exact setup. HIGH low mod with Hid's. i cut the blue wire. and i was just fine. so. i think you cut the wrong wire. and that WAS on my 96
