So I found
this site thanks to a bit of searching, since I couldn't find it ANYWHERE near me. My question is, they don't show amber in their inventory. Do I have to mix yellow and red???
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
I used Orange Dupli-Color Metalcast to paint my corners orange/amber
So did you just spray a light layer, or did you spray it like you were painting an interior piece?
2000 Camaro V6.
Not to thread jack but would it be a good or bad idea to spray transparent amber inside black corners, on the lens and on the black paint? Would the black paint act like a base coat to match black headlights?
If you go to auto zone, duplicolor makes something called
metalcast. Its a anodized look paint for shiny metals. Its basically a transparent coloring.. but i think it has some metallic in it maybe as well but not sure. ive heard of a few using that. They also make a adhesion promoter(cant find it on there site exactly, but if u go into the store, ull find the metalcast it should have the metalcast adhesion promoter next to it) that is clear. Being ur not going to primer or paint the corners u might have adhesion problems, so i would look into getting the clear adhesion promoter.
WhininZ
I just painted the corners like I would anything else. Just make sure you clean the lens real good with some soap & water, dry throughly & get the Adhesion Promoter, it's a clear primer, then start putting layers on.
^^ i completely missed ur reply.. or i wouldnt have made mine lol
Could you get away without using Adhesion Promotor or is it a must? Is that also available at AutisticZone?
-Mark
2002 Cavalier LS
i would recomend using it.. like 4$ will save u a ass ache in the long run
Well I found some stained glass paint.......I was painting it and thought I screwed it up cause it looked like it wasn't tranparent.....but I came back 2 hours later and it was!!! But I need to put some red in it cause it's too yellow now lol.....
Thanks for your help guys!!
2000 Camaro V6.
i got an idea maybe...
whut if we take the corner lense off and spray the inside with the orange paint???
...wont that make it so we wont have to re-spray every year.
like if it wears off? [especially us with snow/salt in the winter]
