Hey all
Would running silicone around where the clear and black part of the lens come together, be just as good as taking it apart? I thought it would, but wanted some input.
Thom
1998 Z24
huh??
are you having a problem, and looking to seal the headlights??
or are you planning on taking them apart for other reasons and re-sealing them??
I have a little bit of moisture, I was thinking instead of taking it apart, just running a bead of silicone around the seam where the clear meets the black back part.
1998 Z24
get all the moisture out, and run a bead of clear silicone all the way around. should cure it right up
thanks for the input, just gotta pick up a tube of silicone
1998 Z24
