Is there any variation of the spoiler bolt patterns on 3rd gen trunk lids? Are they all the same?
"The J's weren't designed to be sports cars, the suspension sucks, the brakes are tiny, and the target market for our car doesn't need to be able to do any more than 65mph." - Shifted
A more accurate observation has never been typed. These should be the starting points before any serious performance modification. What's the point of making a serious performer if you can't control it's power?
im sure there all the same .. wait no i am definitly sure there all the same..
on my 03 i swapped it out for and 02 spoiler.. on my 99 i swapped it out for an 02 spoiler as well .
if you go from the 95-02 to 03 style, you will have 2 extra holes
so not definitely the same
why stop at the 03? 04 and 05s are the same .. unless your talking about those few cavs with the sunfire sedan and grand am spoilers. which have the two pedistals
awesome with the quickness! Thanks. I was opening up my options for replacing my '03+ trunk lid. I was hoping it could be either a z or base w/ spoiler 95-02. Should make my choices a little more open at the junk yard.
any trunk lid from a coupe and sedan cavalier will work for you... and also with the sunfire sedans .. they use the same trunk lids .. (coupes dont count)
this is getting easier by the moment.
oh forgot to mention the cavalier convertible is also the same as the sedans and coupes ..
sunfire sedans have the light bar across the trunk though so youll either have to leave that on or weld the 8 or so holes that are underneath
yea forgot about the light bar.
yea if you plan on putting the 00-02 z24/ ls sport spoiler your gonna need to find a 95-02 cavalier sedan/coupe or convertible trunk lid. why? because the 03-5 cavalier light bar gets in the way of the lower part of the spoiler. most likely the same reason as the sunfire trunk lid.
or save for the headaches on find a trunk without holes and try to get the rk sport CF trunk bezel
I wanted to eliminate the lightbar all together. I'm basically swapping the front and rear of this car from an '04 to an '02, minus the ls sport rear fascia. If I can find someone to part with an Xtreme tuner rear, even that will go.
Xavier Canon wrote:I wanted to eliminate the lightbar all together. I'm basically swapping the front and rear of this car from an '04 to an '02, minus the ls sport rear fascia. If I can find someone to part with an Xtreme tuner rear, even that will go.
im doing the exact same thing on my 05 cav.. but im going z24 99 front and 02 trunk with 03+ razzi rear bumper.
so lemme get this straight....
an 00-02 z24 spoiler will bolt right on my 95-99 trunk lid that has the 95-99 spoiler on it?
z yaaaa wrote:so lemme get this straight....
you gave to take the old spoiler off first. the holes will line up. i have a 2001 spoiler on my 95 trunk.
