would i be able to wire up these foglights to a rocker switch inside my cabin and use them? im tired of not being able to see @!#$...
http://cgi.ebay.com/ebaymotors/2001-2007-Subaru-Impreza-WRX-Halo-Fog-Lamps-lights-06_W0QQitemZ220156877180QQihZ012QQcategoryZ33709QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
im assuming if i just run power from the battery, to the switch and then out to the lights i should be able to get them to work. i know its SUPPOSED to be wired to not work with the high beams, but if i had these on, i would be sure to switch them off for high beams. or just not use the high beams...
opinions? i thought the halo's would be neat to use as a parking light sort of thing.
thoughts?
thanks!
OH, they would be mounted in my type J bumper, behind the grills to keep them from sticking out, almost like a stealth light... not looking for super bright lights, but just something to light up the road a bit more...
thanks
no they wont work they will add to much of a parasitic power overload with those light up rings, and disable the cars v-chip from functioning properly thus creating friction on the vtec moduale and could start a fire.....
wow that was confusing... lol
i think i can translate that though....
so your saying if i disable my vtec power module from the alignment ring and make sure the light portals dont touch the v-chip then i should be alright?
in short... you dont like the halo's on them... lol
i was going to be using the red halo's or the white ones but its just a feature of the lights... i was planning on white lamps and white rings while driving...
idk its early... i have no clue what i just typed.
wire it right. lights to relay, relay to power and switch. and honestly, that's  HUGE foglight for a cav... i dont think it'll look as good as you're hoping.
im planning on putting it BEHIND the mesh so you wont see it... but i would like to find 3" lamps... i wasnt a huge fan of the size at first...
thanks for the tips... if you run across 3" lamps please let me know about it
Herb Wilson wrote:wow that was confusing... lol
YOU GOT IT MAN! those will work perfect as long as the light portals dont come in physical contact with the v-chip.
Kardain wrote:http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/foglites.htm
Find a switched power source (park light wire works) and use that in place of the fuse panel in the diagram
thanks for the link... im glad i could actually see it... where would be a "good place" for such an elaborate relay?
*** still looking for 3" lamps if anybody has any please let me know***
Auto parts store... there are relays with sockets and wire leads... packaged as a "fog light relay kit"... usually in the same area as the electrical connectors and/or bubs
Either that or ask for a DRL relay and socket for a 97 Sunfire... they should give you a 5 pin relay
