Body Kit swap Z24 - Exterior Forum
Body Kit swap Z24
Saturday, August 18, 2007 5:07 PM
ok know this is a bit older than the norm:
Want to put body kit from 1990 Z24 on my 1993 VL (cs)? Possible?
The donor car is 2-door, coupe hatchback Z.
My car is 4-door, 6-window VL model.
Same generation wonder if body style make a difference.
Anyone out there with bit o' knowledge, Thanx
Re: Body Kit swap Z24
Sunday, August 19, 2007 12:53 PM
It can be done, yes. You should swap over the headlights, though...Ph1 kits dont look right with Ph2 headlights...you will need to weld or bolt on the brackets that hold in the lower skirts, and drill holes in your doors to fit the upper skirt...
