Well mine is rusted so bad more gas hits the ground than the tank and i need to get it replaced.. anyone have a part # or anything like that for me? advance and autozone said they cant get it.
couldnt you use plastic tubing?? I remember a few ppl on here who moved there filler location and used plastic tubing for it.. If i find the post Ill bump it up
Gas Tubing
Im guessing to just cut the areas that are rusty and use that tubing. Cause you only need the upper peice(filler) and the connection area to the gas tank.. I maybe be wrong but this seems like a quick fix till you could find a replacement.
cmon, you should know i have what u need
