Door wont line up.. err... - Exterior Forum
Thursday, May 24, 2007 11:23 AM
Hey, I was recently in a acident, bought a new door, and a new upper hinge. NOW my problem is the top part of the door looks like it is sticking out.. I have a 2k+ vehicle, and I used a hinge off a 97 z24, which had a little dimple which I hsaved off so it could fit on mine.. NOW I am wondering, is this the hinge that is the issue, or is it the door ? The door could be slightly bent, or the hinge from a pre 2k could be different as well.. I am unsure.
My Cav
I give up...
Re: Door wont line up.. err...
Thursday, May 24, 2007 11:47 AM
the hinges and a doors are the same on all 3 gen j-body coupes.
loosen the bolts on the car itself, have a friend push on the top of the door and pull out slightly on the bottom whil you tighten the bolts. if that doesn't work, repeat the proccess on the bolts on the door. you may have do this a couple times
if that doesn't work, then something is bent/warped
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
Thursday, May 24, 2007 12:21 PM
i would tape the door in place where it should be. then pull the fender off, take off the hinges, and reposition perfectly. then reinstall everything.
if that dont work, then like Andew said, somethings bent
Thursday, May 24, 2007 2:34 PM
Joey Baggs (Eazy716) wrote:i would tape the door in place where it should be. then pull the fender off, take off the hinges, and reposition perfectly. then reinstall everything.
I concur
Thursday, May 24, 2007 4:16 PM
Did take the fender off and such, I am thinking it is the door now..... Looks like ill be in the market to get a new one...
My Cav
I give up...
Friday, May 25, 2007 5:54 AM
i'm willing to bet that the door is bent and is a result of someone prying the top of the door open to get the door unlocked or to fish the keys out through the top of the door. OR it damaged by an accident OR a 300lb gorilla.....just a thought
Friday, May 25, 2007 6:12 AM
COGcaviZ24 wrote: OR it damaged by an accident OR a 300lb gorilla.....just a thought
lmao
Friday, May 25, 2007 11:22 AM
aren't gorrilla's around the 400 to 500 range ? lol
My Cav
I give up...
Friday, May 25, 2007 4:03 PM
are you sure it is the door?? and the a-pillar didnt` get bent from the hit
a door can be tweaked to fit no biggie if your having problems now iam sure the a-pillar is bent
ya need to have the car pulled
FYI where i work frame labor is 75 an hour
can i haz bondo
Friday, May 25, 2007 4:26 PM
Short Hand wrote:aren't gorrilla's around the 400 to 500 range ? lol
Not the baby ones!
Friday, May 25, 2007 7:06 PM
thats what i was thinking, it doesn't take much to bend them, even 1/4 of an inch will make it a nightmare to fix.
http://registry.gmenthusiast.com/images/my2005cav/my%20car%20the%20bash.jpg
Saturday, May 26, 2007 9:33 AM
ya want to check if the a-pillar is bent here what ya do
get some shims and put them to the hinge to the a-pillar if it takes allot to line up the door then ya the a-pillar is bent
the door can be bent to fit iam tellin ya no biggie, your problem is the a-pillar
can i haz bondo
Saturday, May 26, 2007 11:45 AM
Do the Door hinges allow the door to move backward any? I have a problem with the fender being too far back (Close to the door) and it rubbing. Is there slotted holes on the brackets so I can loosen the bolts and move the door back a 1/4" - 1/2"?
Tuesday, May 29, 2007 5:43 PM
dude right there the a-pillar is is damaged, no adjustment right now will help ya out sorry dude
can i haz bondo
