WHen I was disabling my DRL's (which BTW is an esay process) except if your me. My splicing/cutting tool was way to sharp for that little wire and i cut it far to short, not enough room for me to work with in that awkward little space. So i just connected the blue plug back in the BCM with the DRL wire cut.. turn on the car.. DRL light on dash flashed and made a sound 3 times then the service light came on.. thats all. Is this a problem? I can live with the service light being on.. will that be the only problem, I checked the lights they all work, except the DRL's lol............i did this because im getting a 6000k HID kit installed.
fix it, im sure you can figure out some way to strip more wire off. without it you get a service light, it may not be a problem for you but come inspection time it will be.
