My 2003 Cavalier headlight housing plastic is starting to fog over from the inside. I've kept the outside clear using Meguire's plastic polish. The plastic housing cover appears to be glued to the headlight assembly. Is it possible to replace just the clear plastic headlight covers or do does the whole headlight assemble needs to be replaced?
pull the headlight out, mine has a weep hole. jsut open the tiny hole, bring the headlight inside for awhile, headlight will dry out, then plug it back up and reinstall it.
reply to email:
then i have no idea
