Installing hood pins - Exterior Forum
Saturday, May 06, 2006 4:46 PM
Can anyone give me some tips on installing hood pins in a carbon fiber hood. I'm really nervous about drilling into my hood, how do you do it without making a mess..
Reality is an illusion caused by lack of drugs
Re: Installing hood pins
Saturday, May 06, 2006 4:53 PM
man...id just take it to a shop, that way its their fault if it gets messed up. I wish i could give you some helpful advice other than that...its not that expensive either.
Saturday, May 06, 2006 7:00 PM
Personally i to would take it to a shop. When your nervous is usually when u screw up. You dont want to mess up your hood, let the shop be responsible. Like said above, it wont be expensive. i'd say they would charge you the hourly rate of an hour, so 45-60 bucks depending where you are.
Monday, May 08, 2006 7:52 AM
Use a dremmel, not a drill. The dremmel spins fast enough that you won't crack or chip the hood. Worked great for me.
__________________________________________________________________
Performance cars do not win car shows and show cars do not win races.
It's up to you to decide which you'd rather win.
Tuesday, May 09, 2006 7:12 AM
install the pins, put some lipstick on the tips of them, lower the hood until it touches, then you know where to drill, tape off the top of the hood to prevent cracking the clear coat, drill a small pilot hole, make sure the holes are lined up properly, then drill the larger hole, not that hard, just take your time and measure it atleast twice
Tuesday, May 09, 2006 7:24 AM
99fireSE wrote:install the pins, put some lipstick on the tips of them, lower the hood until it touches, then you know where to drill, tape off the top of the hood to prevent cracking the clear coat, drill a small pilot hole, make sure the holes are lined up properly, then drill the larger hole, not that hard, just take your time and measure it atleast twice
same thing i did (but i used tooth paste, lol)
RIP Saint ........ JBO
Tuesday, May 09, 2006 8:32 AM
Awesome, thanks guys
Thursday, May 18, 2006 4:43 AM
Ok so my pins arrived and the instructions suck. I think there is 3 round plates and 1 rubber one, I would assume the rubber one goes on top of the hood under the stainless plate and then the last one goes under the hood itself, does that sound right? Also were is the best place to mount them, behind the headlight area?
Tuesday, October 14, 2008 4:28 PM
I would mount them right around the rubber stops by the headlights.
Wednesday, October 15, 2008 7:14 AM
I am going to guess he has already installed them, since this post is 2 YEARS OLD!
Wednesday, October 15, 2008 7:31 AM
lol
Wednesday, October 15, 2008 8:20 AM
HA!!
lol
