Clear coat - Exterior Forum
Clear coat
Sunday, March 12, 2006 4:11 PM
My car has a bubble in the clear coat on my hood. It's been there a while and it's not getting worse, but I'd like to do something about it if I can. Short of removing and repainting the whole hood what can I do? I don't mind the way it looks now I just don't want it to get worse, is there anything I can do to protect it from bubbling further?
You can't outrun the radio.
Re: Clear coat
Sunday, March 12, 2006 7:03 PM
if it is rust the correct way would be to sand blast the rust gone
if it just is the clear bubbling off then it was a bad prep and paint job
sorry not to much you can do to prevent it from gettin better short of gettin it re painted
can i haz bondo
Re: Clear coat
Monday, March 13, 2006 7:19 PM
It's not rust, just a little bubble. Would it look like poop if I just dusted it with clear coat to keep water from getting in there?
Re: Clear coat
Tuesday, March 14, 2006 4:10 AM
ok so your sayin is the clear is bubbled and peelin off
no don`t do that it will make it worse, it must have been a re paint and a bad one at that
so take it to a shop and let someone else re do it
can i haz bondo
Re: Clear coat
Sunday, April 16, 2006 7:37 AM
you could try colour sading it, just sand till your throught the bad clear coat, and re-clear it. MAKE SURE TO USE SUPER FINE GRAIT PAPER, AND SOAPY WATER! 2000 grit will work, soak it WELL in soapy (not sudsy) water b4 hand, and have a spray bottle of soapy water to spray the car with. then you should be able to re-clear it, reccomend removing the hood for this
Re: Clear coat
Monday, April 17, 2006 8:49 PM
sunfirepower97 wrote:you could try colour sading it, just sand till your throught the bad clear coat, and re-clear it. MAKE SURE TO USE SUPER FINE GRAIT PAPER, AND SOAPY WATER! 2000 grit will work, soak it WELL in soapy (not sudsy) water b4 hand, and have a spray bottle of soapy water to spray the car with. then you should be able to re-clear it, reccomend removing the hood for this
thats good but you dont need the water just some 1500 or 2000 grit paper on a DA at low RPM's will do fine just remember to buff it when you're done
