I just got a new bumper and i need step by step instructions on how to remove the stock bumper.
2002 cavalier
well you should search first then fill out your profile so we know what kinda car u got.
He has a 2002 Cavalier...kinda obvious.
search, i must of posted how to do this like 15 times already
i got a new labtop the other day
LOL^^^
Basically, remove all the splash guards, remove the little clips holding the center to the actual metal bumper, probly have to take the headlights out, and theres 2 bolts on each side holding the bumper to the fenders.
Someone correct me if I'm wrong....its been a while since I took apart any 00-02s
Just pull on it. It will eventully come off.
Use the search button.
Buy a Haynes or Chiltons manual....$17 well spent...I have them both, and they cover everything between pulling out the engine and pulling out the cigarette lighter...
89Sunbird wrote:Buy a Haynes or Chiltons manual....$17 well spent...I have them both, and they cover everything between pulling out the engine and pulling out the cigarette lighter...
x2...If you plan on doing anymore mods this is great investment.
screws in the fender liners,
the push tab things in the center,
take headlights off srews between fenders and front bumper,
pull down and out.
reverse for install
i searched front bumber removal in all forums, and in all messages and all i came up with were a bunch of rear bumber removal topics. I never get good results when i use the search button. Seems faster to just post it and get an answer or a link to an answer.
Ex wrote:89Sunbird wrote:Buy a Haynes or Chiltons manual....$17 well spent...I have them both, and they cover everything between pulling out the engine and pulling out the cigarette lighter...
x3...one of the best investments ive ever made.
this useless post brought to you by the alcoholic known as LUNDiS
Big Boi -Coloradojbody.org- wrote:screws in the fender liners,
pull down and out.
reverse for install
He got it on the head.. 4-6 Screws(or 7mm, maybe 10mm bolts) in each wheel well, 4 pins by the latch between the headlights(need a flat head to just simply pry them up), Take out headlights and corners out (2 bolts on each headlight 13mm) Then u can look in there and you'll see two 7 or 10mm bolts..(Maybe screws) Then u just kinda tip the bumper back and pull forward. For anyone who has a 95-99 Z24 there are 3-4 Clips under the bumper.. there is this black air dam under it that has like 3-4 clips in it.. I would have to say the ones holding the fender and bumpers are the hardest to get to.. could easily have taken off the old one and a new one on in a hour esp since u know where all of them are.. Have fun! I know i do takin apart my car
Will a Z24 bumper fit on a base model?
bump
Don't dig on the newb's sig!!!
^^^^ Yes.
Saab Turbo Project... 2006
Start taking off all the screws you see, take off your headlights and pull.
