as long as you don't screw something up, your headlights should work normally when you use the switch, but not come on when the car is in gear/moving and the switch is off.
just cut all the lights off
Just cut this wire that goes in the guage cluster:
No Side effects at all.
Ok geat. DO u have a better pic of where the wire is located?
EnviouZ does your low beam and high beam work?
The Chronicles of Dust
View the website and read the Novel.
http://dustnovel.webs.com
it is the small blue wire beside the only purple wire in the harness works great
