WHICH HID KIT?? help for eBay projectors - Exterior Forum
Wednesday, September 21, 2005 4:03 PM
i was wondering if someone could look on ebay and point me to what HID kit i will need for ebay projectors i heard some temps. could burn the projector? i really have no idea.. what kit do i need 9006? ect all i really care for is to make the actual projector blue.. what is the most BLUEST kit. temp ect? thanx
Re: WHICH HID KIT?? help for eBay projectors
Wednesday, September 21, 2005 4:09 PM
Well I'll tell you this the bluer you go the less visibility you'll get.
As for the ebay projectors some take 9005 for both bulbs. Which ones are you gonna get.
IMO the ebay projectors suck even with hids.
04 Cavy LS Sport
^^^^ My Custom Projectors ^^^^
Wednesday, September 21, 2005 4:11 PM
9005 for both bulbs wut do u mean?
i want these
http://images.andale.com/f2/130/124/10545592/1128570841514_1125637973634_GM230_B1B10.jpg
which hid kit would i need?
Wednesday, September 21, 2005 4:14 PM
I'm not sure about those but I think that they say HB3 above the low beam and high beam. In that case HB3=9005
So you will need 9005 for low and another 9005 for high.
04 Cavy LS Sport
Wednesday, September 21, 2005 4:23 PM
i dont care bout high beams.. i just want my projectors to be really blue.. wwhy would it be 2 9005?.. will the harness still fit in the projectors
Wednesday, September 21, 2005 4:30 PM
It would fit but you would need to remove the notch on you 9005 bulbs to make it fit. Sand it cut it. Check the pic out.
Once you have that notched removed you can now put a 9005 bulb into a 9006 socket.
04 Cavy LS Sport
Wednesday, September 21, 2005 7:44 PM
your HID kit should be the same bulb size as the existing bulbs in the light...
You can order any kit, and then go get the HID bulbs of your choosing... over here at the shop we distribute through NOPI and can get any range of HID lights in any bulb harness style.. .so check NOPI and see what you can find for bulbs...
A lot of companies (including NOPI) are no longer making HID kits because the government is cracking down on the production of them... ... so get them now while they are still around... Most companies that made the kits that no longer do, still sell bulbs... even though HID bulbs take a LONG time to blow...
