My stupid cars low beams.. need help - Exterior Forum
Thursday, September 15, 2005 11:50 AM
I'm on my last nerve right now as far as j-bodys go and their stupid lighting systems.Every j-body i've ever worked on has had some kind of a lighting problem.
My orange car had one of the main harnesses melt almost the whole length of the car, this was related to the parking lights somehow. My brothers cavalier has screwed up turn signals that only work when they want to. My girlfriends sunfire was without turn signals all summer untill i was finally able to figure them the @!#$ out.
Now i'm on my new car, its a 97 cavalier, auto, 2.2, yeah.... the turd edition. The low beams wont work now. I tried swaping out the cluster, that wasnt it. I tried swaping out the switch, that wasnt it. The fuses are not blowing, so theres no short anywhere.
I'm seriously about ready to destroy this car, im so pissed right now. Any help would be greatly appreciated!! Maybe even a cookie would be instore for the person who solves it
Re: My stupid cars low beams.. need help
Thursday, September 15, 2005 12:08 PM
damn question, but did you try new bulbs??
i meant dumb, sorry
Thursday, September 15, 2005 12:13 PM
yes, i even went to the new silverstars, still nothing, the high beams work fine
Thursday, September 15, 2005 12:47 PM
Bad relay i would be need to get out the Fluke and start testin
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
Thursday, September 15, 2005 12:50 PM
My rear turn signals only work if the brakes are on But thats cause I went from 2-bulb tails to 1-bulb tails...
Thursday, September 15, 2005 1:20 PM
john harrington wrote:Bad relay i would be need to get out the Fluke and start testin
are you talking about the one up front on the bumper, cause if you are i already tried that to
Thursday, September 15, 2005 1:29 PM
my 99 sunfire is the same way....the low beam on the drivers side doesent work but the passanger side does....all I do is drive with my high beams on. The car is low enough to make it look as if my low beams are only on.
Thursday, September 15, 2005 4:03 PM
anyone else?
Thursday, September 15, 2005 5:06 PM
Have you tried a whole new wiring harness yet? We had to do that on my g/f's since the previous owner @!#$ somthing up. Cured all the problems.
Thursday, September 15, 2005 7:47 PM
C R J wrote:Have you tried a whole new wiring harness yet? We had to do that on my g/f's since the previous owner @!#$ somthing up. Cured all the problems.
no but thats what im afraid of
Thursday, September 15, 2005 7:50 PM
dont mean to change the post but hows the engine coming meckster?
Saturday, September 17, 2005 9:44 AM
This is going to suck and a pain to do, but get out the tester and start at the last know source of power and troubleshoot that way. Might want to check the low beam switch itself and make sure the switch is working, then thats to check your wires. It might just be a bad wire, in that care replace it. Check fuses or relays if there are any. The easiest way to check your wires would be a continuity tester. It will usually beep or flash or signal in some way they you have good continuity between your wire. Hope this helps. Let us know how its coming. If i can think of anything else i will let you know.
<img src="http://registry.gmenthusiast.com/images/atmosjumper/personal_pic.gif"/img>
Saturday, September 17, 2005 10:24 AM
just use ur high beam as low beam... by that, put in high beam harness + bulbs into low beam part of your headlight housing, that way you can use high beam as your low beam until you figured the whole thing out which might take some time...
then you just won't have a high beam which you won't use that often anyways...^^
<img src="http://www.j-body.org/registry/bulewold/smashimaro%20mobile.jpg">
HTTP://BLUEWORLDKOREA.COM ; HTTP://cardomain.com/id/bulewold
