04 clear corners - Exterior Forum
04 clear corners
Wednesday, September 14, 2005 6:04 PM
how do you guys do this i would like to do it to mine...pictures would be great if anyone has them too
Re: 04 clear corners
Wednesday, September 14, 2005 7:41 PM
search--look under archive for your question.."--->LINky<--- here are a couple of my pix:
: this below is from that post..
first off you need a lot of time
second 4-5 flat head screw drivers
3rd eather a bit driver or + head screw driver
4th a razor blade
1st thing you do is take off the headlight
2nd thing you do is take off the bulbs
3rd is pry up the tabs on the headlight housing
4th take razor blade and score out the black adhisive as best as you can
5th put flat head screw driver in and gently pry up you might hear a bit if cracking that is eather the housing cracking or the adhisive coming apart
6th go all around the housing with the screw drivers and pop the front lense off
7th take your time removing the lense and dont crack it
8th clean your lense
9th remove the inner black piece of plastic
10th remove the amber plastic lenses
11th put back in the chrome piece that was behind your round reflecter
12 reverse steps and you should be done if not you can email me at cavaliersrus@yahoo.com or if you can live without lights or can store your car for a little you can let me do them ive done 2 sets of them now another guy in missouri not on the org trying to convert him into getting on.
that should do you again if not email me and i will try to help you out or if you want contact me on aim at eather corvetteds3nt or cavaliersus or on yahoo msger under cavaliersrus
if you get it to work cool send me some pics in email
******do this under strict warning im not responsable for any damage done to your car and or warrenty******
l8ter
Chris Follin
Owner of www.cavaliersruscarclub.com
Wednesday, September 14, 2005 8:00 PM
i baked mine in the oven for a little while to help soften the silicon/adhesive.. it takes a lot of time, and is frustrating, but it pays off in the end
also, do you guys know if there are replacement bulbs for the 2 lights ? they are yellow compared to the headlight, and would like to make them white lights
Cavillac
Wednesday, September 14, 2005 9:34 PM
[M wrote:ATTRESS] do you guys know if there are replacement bulbs for the 2 lights ? they are yellow compared to the headlight, and would like to make them white lights
thats the reason I left them the stock bulbs, to make the corners slightly yellowish in comparasion but still clear since its illegal for all clear in some areas
Wednesday, September 14, 2005 9:38 PM
^^^ werd...check the laws in your area...they still give a nice circle kinda effect..and Stars..where the heck ya been man?!
Thursday, September 15, 2005 7:44 AM
good info thanks fellas
