tail-light bezel - Exterior Forum
tail-light bezel
Monday, August 29, 2005 9:48 PM
I have seen a tail-light bezel in carbon fiber for my 2005 Cavalier. Does this fit over the red-reflector one now or does is completly replace it. I am trying to black out my car and not with carbon-fiber
Re: tail-light bezel
Monday, August 29, 2005 10:48 PM
it replaces it entirely..........if your trying to black out the car, just paint the reflector, after masking off the reverse lights, or cover it in vynal
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Tuesday, August 30, 2005 6:02 AM
or just get ahold of a 95-02 cavi trunk. bolts right up. just need to get new tails then (aftermarket or 95-02 stockers).
SO EVERYTHING!
Sunday, September 04, 2005 9:57 PM
Do the back-up light remove from the red-reflector? If so how, I looked and did not see how?
Sunday, September 04, 2005 10:31 PM
It is all one piece (ie. the red reflector and back-up lights) the bezel replaces the red reflector part ONLY...reason being that you need 02' or older tailights(inner and outer). They are a direct bolt in on the 03+ cavs as well.
Sunday, September 04, 2005 10:57 PM
so I would need, the tail light and backup light assembly
Sunday, September 04, 2005 11:15 PM
yes if you want to use the cf bezel you need to get these....
or a set of aftermarket tails (euro clears, cf euros) will fit as well but imo took cheap and tacky. Also toyo tails would look nice. Either way you hafta buy some sort of tails to use the cf bezel.
Sunday, September 04, 2005 11:17 PM
an example.....
Sunday, September 04, 2005 11:19 PM
Thank you
