Ok kind of haveing a bit of a problem. i want to get my f1 fenders on my car it is a 2000 The fenders are up to a 99 what bracket has to be cut off for them to fix the 2000? Also since i dont got the door part of the drift sides and there is that part that goes up the fender in the front isnt it going to go up to far for the vent? any idea what i should do ? i was thinking of cutting the part that goes up the front fender off at the very bottom but not sure how that would look
P.s. side skirts not painted yet so dont got to wory about spidering paint
PaCavalier
*Sponsored* by
WWW.CUSTOMANDSOUND.COM
For all you polishing and coating need's
well you would have to put them on first to see where the skirt goes up to. you can cut it off at the bottom, ive seen it done and it doesnt look bad. as for the fenders, just take your bracket off your stock fender and put it on the new one
I though there was a bracket on the fender its self that had to be cut off for the 2000+ headlights to fit since the 99 headlights where way smaller
PaCavalier
*Sponsored* by
no i believe its just a different bracket thats all. i know the 95-99 use different ones than the 00-02. i believe you just take it out and swap, no cutting. dont quote me on that but im pretty positive. im sure if you search for the headlight conversion you will find an answer
