hey guys two quick questions for all, i just put 92 accord clear bumber leneses in my car and accidentally drilled into the housing on one and now i have moisture in it how do i go about getting it out and will caulck do the trick to seal the hole?
also my one headlight just recently is showing moisture in it how would i go about getting that out?
thnx in advance -chris-
the easiest way to get it out is to
SEARCH
You can use a blower to dry it out or just let it sit in the sun. Then when it is all dry on the inside, use that caulk to seal it.
Same goes for the head light.
Not that hard now was it to give an actual answear.
David Alameda (Zspeedcav) wrote:You can use a blower to dry it out or just let it sit in the sun. Then when it is all dry on the inside, use that caulk to seal it.
if only the answer was right. i think you mean SILICONE, not caulk. 2 totally different things
Fred Ohlson wrote:The people that devised this cruel attempt at acceptance and fame burn in there honda civics.
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
Yeah, you can put your caulk in it's crack.
<img src="http://img.photobucket.com/albums/v502/brad_sk88/SigSummer05.jpg" alt="Image hosted by Photobucket.com">
