when i got my car painted the body shop had put z24 side moldings on my 2.2 base model....ive never really liked them that much but i havent pulled them off because i dont know for shure if they painted under them or not
so if i do go and pull the moldings off and its the original color underneath, how would i go about putting them back on? like what kind of adhesive do you use and where would i be able to get it?
My Suggestion would be to use 3m's double sided tape, That's probably what is holding the moldings on there now
yea thanks, my friend said the same, not a bad idea
I used a couple different tapes on mine and didn't work. This one kind of tape did eventually work, but I can't remember what it was called. It was grey and was wider than the others...like an inch probably.
It'll be a bitch to get the old tape off the molding so it'll sit closer to the door when you put the new tape on.
