Ok, ive been searching all day. Someone has to know what clips i need to mount he fog lights to my bumper. Im using the stock fogs from a 95-99 z24 on my base coupe. If anyone can provide pictures or links. I will love you forever.
Celebrating 4:20 Just a little early!
I love you too
On my 99 Z24 there were two holes in the bottom of the metal bumper support (under the urethane bumper. They're probably cut into every single front bumper support.. cuz I think the bumper support is the same 95-05.
There's a round hole, next to a square cut out. Then there's a clip slipped into the square hole.. so the threads line up with the round hole (I hope this is making sense). there are two 10mm bolts that thread into those clips, which hold each of the lights in place.
They are just typical body clips... same as the ones used on the fender-to-bumper part... you should be able to get them at any parts store.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
now, john now that i have them mounted, what do i need to wire them up, id like to use the stock switch and keep the stock look. I understand that from my studying that i need a headlight wiring harness from a Z24 similar to my year. I wanna know what im looking for so that i cant just pull this a the yard.
