suicide doors - Exterior Forum
suicide doors
Saturday, May 21, 2005 6:35 PM
when you put on suicide doors, can you still open the doors with the stock handles from the inside, or do you have to use the poppers there too?
Re: suicide doors
Saturday, May 21, 2005 6:53 PM
depends on how you set it up, if you rerun the stock linkage so that it will work the new latch then yes you can use the factory inside handle, if you prefer you can just put a push button or somethin of the like in the door panel so that you have the release solenoid doing all the work for you, also if your doing suicide doors anytime soon check into emergency releases, i beleive it was aplusperformance that sells a manual release cable you can tuck up in the front fender well so you can get in the car if somethin happens and your battery dumps.
J~
