Rear and Front Bumper Questions - Exterior Forum
Tuesday, May 10, 2005 5:55 PM
REAR BUMPER
ok today i took the screw things in my trunk out so the carpet would come up...
i removed the two bolts for the back bumper that are on the side of the car and the two screws in the wheel wells......
i also took the four plastic clips out of the bottom....
its loose but not quite coming off do i jsut pull or do i have to take my tail lights off to get to the filler pieces under your tails... then will i have access to the bumper or can i do it without taking that filler out??
Front Bumper:
on the front i took the radiator cover off then removed head lights i see the four plastic clips..i removed those
then took screws out of the inner fender.again it was loose wats holding me back on the front is there anything on the bottom of the car or right where it goes from the front to the side....
please help me
also im ordering a BC2 are they known for good fitment
from winksonline.com
thank you
Re: Rear and Front Bumper Questions
Tuesday, May 10, 2005 6:04 PM
back bumper theres two screws in each fender, two bolts on each side of the trunk, and four of the rubber grommet things underneath the bumper. you'll have to pop the bumper by the fender out first or reach inside the inside of the fender and theirs a few more screws/bolts. then it's just a matter of pulling it off. remember to pull your license plate bulb out. you don't have to worry about the fillers. they won't be in the way and it's actually set up that those should come off after the bumper is off.
front bumper theres the 4-6 grommet things under neath the radiator cover and headlights (i believe), the screws in the fender and the grommets underneath the bumper. should just pull off after that. remember to pull the bulbs out of your bumper lenses. this one might not be exactly right as i haven't pulled my bumper off in like 8 months.
SO EVERYTHING!
Tuesday, May 10, 2005 6:07 PM
behind the headlights there are 2 bolts. the rear once you get the 2 out of the wheel well, just pull it off and twist out the light for the license plate.
Tuesday, May 10, 2005 6:14 PM
yeah i got those two behind the headlights and it came like off of the frame then it wouldnt move by the filler
Tuesday, May 10, 2005 6:15 PM
also i did take the screws out of the wheel wells do i just have to pull harder...
Wednesday, May 11, 2005 8:15 PM
anyone???
Wednesday, May 11, 2005 8:18 PM
The screws on the wheel wells go down underneath the bumper. Follow the wheel wells along until you find where the screws are.
