does anyone know how to remove that stupid black pin stripe that going down the side of my car i cant stand it .
pull.
Heat gun or Hairdryer or in the sun after an hour. It should be fairly
easy to remove once it's been heated up.
<img src=http://www.krimotorsports.com/images/graphics/newjbosign1210.gif>
________<a href="http://www.krimotorsports.com?source=JBOsig"><img src=http://www.krimotorsports.com/images/graphics/krimotorsportsbluemini2.jpg>________
"Your Premier Source For Automotive Neon & Accessories!"
if you can get ahold of a pressure washer, they make a tip to remove them. Thats what i did on my old car, i had the gay wave type decal and then pin stripes also. It was all off in about 10 minutes. Just make sure to stay away from edges on the car (fender wells).... It will blow the paint off.
Easiest mod ever.
Use your fingernail to lift up a corner of the pinstripe. Once you can grip it with your fingers. Pull slowly.
Peels right off.
"Eagles may soar, but weasels don't get sucked into jet engines." -- Steven Wright
mine got clear coated over, so i dont think it will be coming off soon
