I tried to search and I only found the wiring conversion from 2k to 99; and also the conversion from 99 to 2k
Ok, I whant to do a FRONT conversion from 1999 cav to 2K .
is this correct ?
I need
1) 2K headlights
2) front bumper
3) good
4) 2 fenders
5) corner lights
6) and do a wiring conversion ?
or can I keep my fenders or hood ?
thanks
Fenders are the same from 95-02. and not sure what item #3 is
Words that you can't use in modding: Finished, Perfect, Cheap.
hood is the same too, didn't see you asked that.
I need an edit button!! Fenders are the same from 95-05 for cavaliers.
doh!
I whant to change to this lights
From
actually fenders ARE NOT the same. the 95-99 fenders have an area to bolt the corners on to the fender, 00-05 fenders jus have brackets that have holes to slide the pegs on the corners through.
"Lil Brudder! He's got the heart of a champion!"
^^^i think that is what the harness is for
http://img37.exs.cx/img37/2828/dacopy0wr.jpg
WWW.sinisterambitions.com
True the 95-99 fenders have a bracket to bolt the corners too, but so do the 2k up. To complete the conversion you will need the mentioned parts. (Headlamps, Corners, and Wiring) and then you will also need to get the correct mounting brackets for the 2k headlamps.
When you get ready to do it you need to drill out some spotwelds for the 95-99 corner bracket and then use the 2k bracket...no welding is necessary. This is the way I converted mine to the 2k lights.
P.S. if you need a wiring diagram let me know I can e-mail it to you.
<img src="http://www.j-body.org/registry/tankdogg/tnk.jpg">
"To all those who cant handle the truth...Face it Our Reality is Your Fantasy"
why would you want to do that...lol
if you want, i can trade ya! im lookin to do a 95-99 conversion
FEAR THE MINI
