neons help - Exterior Forum
neons help
Sunday, March 27, 2005 12:22 AM
anyone got tips where the best place is to mount these so no bulb shows n r protected the best? also im havin problems findin a safe place to run the wire on the front... any help is much appreciated.
Re: neons help
Sunday, April 24, 2005 10:56 PM
sideskits, rear bumber brace, and in front or just behind radiator
Re: neons help
Monday, April 25, 2005 7:17 PM
Matt I ran mine in between the pinch weld and the sub frame and for the rear right up behind the bumper support and on the front right behind the core support in front of the two rails that run up to the core support from the lower control arms..
if you need pics I can get some of my set up you can t see anyof the tubes and it looks way better than bending down and being able to see em , on mine you almost ahve to be lying on the ground to see any of them,, as far as the wires I took a piece of wire and ran alll my wires through the frame rails so about all the wire you see is the three inches from the tube end to the hole in the frame and remeber dont solder em just twist em togther and bend em over each other then heat shrink tube em so they wont get corroded...
hope that helps, later ...Dave
