i wanted to get some answers from those who have done this...let me break it down in dummy terms so that were all on the same page...
i have a 2000 cav
i have a set of black projectors for a 95-99 model cavalier
i have a set of 95-99 clear corners (soon to be black)
i have a set of 97-98 toyota supra signal lamps
i have the toyota cavalier body kit
now to make this a sucessfull swap what do i need??
can i use my current headlight wiring harness or do i need to pull one off of the junkyard??
also if any of you have done this, do you have any suggestions??
FEAR THE MINI
Why are you changing the headlights? 00-02 headlights looks so much better and lines up much better too. Your gonna have some hard time algining the projectors since their fitment sucks. You can always trim the front bumper to make the 00-02 headlights to fit.
If you want to stick with the projectors. You will need 95-99 fenders because they have brackets for mounting the corner lights. You can spilt the wirings to older blub sockets. Here's a diagram. Hope everything helps!
<img src="http://phewes.snowpants.org/diagram.jpg">
- Darren
<a><a href="http://phewes.snowpants.org" target="_blank">
<img border="0" src="http://phewes.snowpants.org/summer2005.jpg" alt="get off my sig!" width="338" height="112"></a>
talk to lenko about wiring up the turn signals for the trd kit.
so if im reading thediagram right, i can use my stock wiring harnes to separate the low beam and high beam?
what about the corner lights? just extend the wire from the corner light to the supra corner light and fender bulb light???
FEAR THE MINI
YOUR A GOD!!!! any pix by chance?? if i'll post em in your forum when im done with my conversion....
FEAR THE MINI
