i put a sticker on top of my sunroof. and i put it on very carefully, seeing no airbubbles until i took the top strip of paper off and there are tiny little ones that i want to get out.. they arent huge or even noticable unless you stare real close but is there anyway to flatten it out?
http://www.cardomain.com/id/beltzie21
take a very fine tipped needle/pin and pop them and press it down. Should work just fine, just be very gentle.
Click Sig For Pics
You might try waiting a day or two, a lot of the bubbles will sometimes go out on their own.
^^^^^^^^^^^ What they said. They should bake out in a couple of days. I'd avoid poking them because you'd have a tiny little dot of light coming through. I didn't think so either but i did it once and there it was, light!
i've had it for a week or so. my dad told me to leave it go he told me once it sits in the sun for a while they should go down . i guess ill just wait lol
thats why when I put stickers on, I spray a little windex on the windshield, so I can rub them out easy and move it around also. It doesnt hurt the way the sticker, sticks
http://www.ohiocichlids.com <<<<If you keep cichlids
also, with the windex trick, use a heat gun, that'll get the sticker to sit better, its like window tint. Use the heat gun, being careful to only hold it over the sticker for a little while, and with a bondo disk/credit card press out the bubbles.
use a credit card or other plastic card type. when i did mine, i peeled the backing off at a 45 angle and as i slowly laid it on, i was running the card across the sticker to lay it flat. no bubble for me
