I have an under glow kit lying around and decided to put it on but i need some help with the wiring so if some one can't point me in the right direction that would be great!!!!!
Spankzz
Hahahaha!!!!!!! Thanks tips!!!! Obviously they arn't for @!#$in rookies like me!!!!!! Main question is where do i hook up the power to, all i gots is a little red and black wire, and ya i know the positive negative part too!!!!!
Spankzz
With the red wire, run it to a switch. Mount the switch somewhere inside the car, and then run another wire from the switch to the battery or a fuse in the fuse panel. The black wire you can ground anywhere you want. Under the dash to a metal bracket, or directly to the battery.
<a href="http://webpages.charter.net/nightmare-32/">
</a>
...Oh no I'm a big bad fake moderator...[]Support the ORG, go Premium
<a href="http://www.j-body.org/forums/rules.php">Please, read the rules.</a> | Retired Sig Maker Count: 74</a> | <a href="http://www.j-body.org/~gatewayjbody">Gateway J-body's</a>
