Hey,
I just got my Lambo kit in today and am looking to put the kit on this weekend sometime. i have molded drift side skirts to the car.
Now people who have done this with molded sides or know first hand how its done i would just like some advise that could makes things easier for myself.
Obviously i,m not going to be able to take off the fenders. So what do i have to do to get around this? Or what extra tools makes this job any easier.
I,m sure everyone gets what i,m saying...I just would like to know the best possiable method to the install without getting myself into trouble.
Thanks for any help or advice,
Alex
What I would do is jack the front of the car up. Take the splash shield out and work from there. I think that would be a pretty good way of doing it. Let me know if it works. I might do it with mine.
ummm i don;t think i ever heard of that but that might work. Basically i can tell this is going to be no easy task...hahaha. Thanks David
Any other suggestions.
you might be able to take your hood off and unbolt your fender and have a buddy hold the fender out a little to give you enough room to work if you take your inner fender out. You should be able to get enough flex out of the sideskirts to give you the room that you need. Just make sure you get a friend that you can trust to help you and that will pay attention or you will be replaceing alot more than just door hinges. Keep posted on how you are coming along with the hinges.
3You can ask Brian(Z2FLIP4)...he said he had one hell of a time working with hardly any room....
<b>APlusperformance.com January 2005 Ride Of The Month
Sponsored by APlusPerformance.com</b>
Ratchet wreanches and extensions. I think you can maybe get it done pretty fast that way LOL. Or not.
When and if you go to try this. Take a pic of the amount of room you have to work with. I might just try it and I wanna know how it is to get in there.
I thoguth you had to weld in the Lambo kit? they just bolt on?
I am pretty sure they just bolt on. Correct me if I am wrong.
the Chin-Wah and VDI kits are both bolt on. no welding at all.
yep, complete bolt on.....However its not a easy task now that i have 1 piece side skirt/fender..lol
I like the removing the splash guard idea and a long ass extension.
I think i might try that and go from there.
I with Z2flip4 would put in his imput
there's 4 bolts on the doors, with an extension im sure you can reach the outter two. then, once those are secure enough, you can lift the door and get the inner two bolts. but that is of course as long as you've gotten a couple bolts on the body of the car itself and have someone to hold the door just to keep anything from shifting.
