Hey guys,
well my fiancee's 95 mustang vert has a problem with the headlights. Over time they have become very cloudy and yellowish in color. Its so bad, that i can drive through the city with the highbeams on and nobody even notices. Light penetration is very poor.
Is there anyway to fix this other then buying new lights? Anybody have experience with this?
thanks
Nate
1995 Cavalier W/2k1 Engine
i hear you can use some fingernail polish remover on the outside to clean em up. might try that in a hidden part of the light to see if it helps at all. i had that problem with my old headlights on my 90 toyota.
gettin' organizized...
oh yeah, awesome car in the photos forum, man!
try sanding with high grit sandpaper and then polishing
yeah that's whut you need to do.. use a very find grit.. or Meguire's makes a plastic polish that works wonders! it's amazing whut it does, even takes out fine scratches, and if you have a polishing tool im sure med deep scratches too. I can stand behind it b/c i use it all the time even on cd's.. helps them out alot! fine fine fine grit sandpaper (wet/dry) will work too but you'll have to polish it afterwards so that the shine comes back and it gets rid of the yellow gunk. That's whut i'd reccomend on doing. then use the meguire's stuff to polish it out. Just be SUPER gentle when sanding no need to press hard. then meguires also makes a plastic protector/restorer stuff you put on after the polish that restores the shine & luster to your plastic.
good good stuff tho I use it on my headlights & tails often.
-Saint Augustine
THanks guys, i stumpled across some diys and 2000 grit sandpaper and polish will do the trick.
Dont really want to buy new lights, we are planning on selling the stang. But i should take some before and afters. I have to detail the HELL out of this thing to bring its value up .lol
Nate
i heard from the "chemist" from mothers that u can just use their aluminum polish, then use the plastic polish and they will be as good as new.
this is my sig
