This is bizarre. I bought a pair of led bulbs for my front turn sigs, and a pair of load equlizers. After i installed everything i did a test to make sure everything worked correctly.
Everything works great with my headlights/running lights off. if i turn my headlights or running lights on, once i hit the passenger side turn signal, it flashes fast, and my clock on the stereo as well as the odometer light flashes fast too!! The drivers side led works fine though. what did i do wrong?
arrgh, help!
"Arrgh", are you a pirate???
I have no clue, but I'm sure someone on here does... It really sounds like you have a bad ground somewhere.
"I count him braver who overcomes his
desires than him who conquers his enemies.
For the hardest victory is the victory over self." - Aristotle
recheck the wiring, that is bazzar
"I live my life a quarter mile at a time..." "for those ten seconds or less I'm free"
You waited like an hour for someone to reply to your thread... wow.
Anyway, did you bother checking the wires with a multimeter before you installed the LEDs? What are they rated (voltage and amperage, specifically) at? What about the resistors? More details would be appreciated.
![](http://www.octal9.com/images/sigs/evo1.jpg)
Interior FAQ -
J-Body of Michigan -
i didnt check the wires. didnt know i needed to. these are just direct replacement 3157 led bulbs and a load resistor on each bulb. i thought that was all i needed.
these are the load resistors i bought. its a 6ohm, 50 watt resistor.
load resistors
I have to put a load resistor on each bulb. the resistor "wires" into the stock wiring. what i mean by that is there is no splicing of the wires, it crimps the wires with a metal contact. looks a lot like this:
the load resistors look like this:
so you think its a grounding issue?
