LZM tuning - Tuning Forum
LZM tuning
Tuesday, May 01, 2007 4:33 PM
can anyone give me any info on tuning for the LZM stage 2 cams. i'm ordering those and hp tuners within the next month or so and just looking for any kind of info on them as far as tuning. flame on!!
Re: LZM tuning
Wednesday, May 02, 2007 7:56 AM
I beleive the only problem you should have is Idle/ CEL light(maybe)
If you buy a Zeitronix wideband to replace your 02 sensor you can also change your narrowband switchpoint to accomodate your bigger cams...
Re: LZM tuning
Wednesday, May 02, 2007 9:11 AM
i understand that but what i was looking for is suggestions on making my car run right with cams if that makes any since.
Re: LZM tuning
Wednesday, May 02, 2007 12:09 PM
He wants to know how to tune for the the cams or what area's need to be addressed first.
And I am of no help since I dont have cams and Will be ordering HPT myself soon..
Have you read around the HPT forums yet ?
Re: LZM tuning
Wednesday, May 02, 2007 12:16 PM
well with hpt you can prevent the cel's from coming onwith will solve any misfire problems you might have with large cams. You'll also want to lean it out a bit at idle, throw in a deree of timing and maybe even bump the idle rpm 50. Above 3400 you'll want to run a bit richer, although off the top of my head I can't tell you what afr to aim for to get peak power.
Re: LZM tuning
Wednesday, May 02, 2007 4:28 PM
... since the car is now less efficient at low RPM, don’t you want to turn back fuel at lower RPM...........
Chris
'02 Z-24 Supercharged
Re: LZM tuning
Thursday, May 03, 2007 8:07 AM
tune to stay away from knock id suggest investing in a wideband and Id suggest bigger injectors people think im crazy when I say that but Id even suggest that as a first mod with hptuners since you'll come to find out how our injectors are already stock running pretty much on the limits of critical duty cycle.
