Is this a problem for anyone else? I cant get any reading from my data port. Before using a code scanner I use to be able to play around with it for a second to get it work but now with hp tuners its just not connecting/ Already replaced the cig fuse and its still not working... Any ideas?
check power at pin 16... Also make sure all your grounds are good and tight....
![](http://www.autotap.com/images/connector.gif)
The pins are used in the following way:
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line and ISO/ DIS 14230-4
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line and ISO/ DIS 14230-4
Pin 16 - Battery Power
If your connector has extra pins, don’t worry. Manufacturers can use them as they see fit.
![](http://i3.photobucket.com/albums/y57/imphat0260/IPon19s/Signatures/QWKLN2-2.jpg)
P&P Tuning
420.5whp / 359.8wtq
Check power at pin 16? Using test light or voltimeter?
Having the same problem. Did you ever figure out what the problem was?
MIR/DLC fuse .. check the other posts. this is the 3rd one i've seen in a month
14.82 @ 97 mph
yea It was a missing fuse don't remember which one
I had the car fixed the next day. That was the problem Jason. Since that I've had to have my PCM replaced because it took a crap.
