some of you may know iam rebuilding my 97 2.4l ld9 with high compression 11.1: comp ported head and 2.3l oil pump conversion and a lil more you can check my reg for more details.
But what iam wondering is what you guys would suggest for a method of tuning i was thinking hp-tuner but $650
i was just wondering if theres something else i could use and still get decent results.
If i have to ill just get hp-tuner but i have never tuned a vehicle so i don't know if i should do that ether or is it pretty simple to figure out?
other suggestions ?
wide band o2?
afpr?
hp-tuner?
just need a lil help.
i would appreciate the help.
Thanks a lot,
Paul Tjepkes
Paul Tjepkes wrote:wide band o2?
afpr?
hp-tuner?
All of the above plus a EGT gauge. and being that your doing the 2.3 swap a oil pressure gauge.
what would the exhaust gas temp gauge do for me?
I am for sure getting a oil pressure gauge for the same reasons you said 2.3l oil pump conversion.
What Iam trying to say is there any way i can tune it not having to use hptuner ?
Thanks,
Paul
Wel, since you are N/A, you could get by with larger injectors and a afpr, BUT, what do you all want to do. I see that you are having the oil pump swap done, AND you are N/A. WHat is a key important part to a NA motor, well any motor, but...more so on a NA motor, the cams. U can run some cams that will make power a lot higher in the rpm band now that you have most of the oiling issues taken care of, but, without using HP tuners to get rid of the stock rev limit, larger cams arent going to help much. I would deffinatly get HP tuners and some larger injectors, that is about it, and it will take care of ALL of your needs as a N/A supporter. Also, timing advance is going to play a large part with you, so...HPT deffinatly gets my vote for this.
EGT will make sure you dont melt your pistons with that sort of compression...
well iam going to use ford brown top injectors and an afpr so fuel should be good
But like i said i have never tuned a car with hptuner and would really have no clue what iam doing
one of my friends has some tuner with a laptop for his gtp so he can help me out a lil but other than that i know nothing about tuning a vehicle.
Anyone in the northwest iowa region that would like to help out when i get to the tuning stage of the build?
as for gauges iam getting a egt, a/f, oil pressure,
tuning. hptuner pro
so iam i really going to need the wideband?
Thanks,
Paul
so what all do you think i all really need ?
afpr
wideband
hptuner
egt, oil pressure, gauge
and do i really need all of this
i mean what is all really a necessity?
Thanks,
Paul
Shifted wrote:Wideband = essential to tuning
Oil pressure = nice to know that things are working
EGT = Not so necessary, but nice to have
AFPR = not necessary if you have an AFPR
I think Shifted meant........
AFPR=not necessary if you have HP tuners.
EGT=I think is pretty much a neccessity if you are doing any sort of timing tuning. Plug reading and EGT gauge are the only real ways to see if timing is on, other than a load bearing dyno. People stress a/f ratio's too much on this website I personally think, much more to tuning than hitting a target a/f ratio.
a good tune is a combination of egt, air/fuel, and a bit of luck.... (basically finding out what your motor likes) which requires a dyno.
so you guys really think i will be able to tune this thing myself with hptuner and a wideband with some gauges??????
because like i said i have never tuned a vehicle with hptuner or a wideband actually i have never tuned a car.
so you really think i can tune it my self?
Thanks,
Paul
