The last time I flashed the computer was about 5 days ago and I have put over 150 miles on the car since. The only test that is not complete is the Oxygen sensor monitor. Does anybody have any idea why this is not ready? And is there something I can do to fix this with HPTuners?
I'm not formiliar with HPT but if your car never goes into closed loop, it will never take a reading from your O2. You may want to ensure all of your closed loop sensors are working correctly with a tech2 and make sure the car is reaching opperating temperature.
Cardomain|
Myspace
any of your o2 sensors turned off or have you disabled any codes???
P&P Tuning
420.5whp / 359.8wtq
the only thing disabled is the code that turns on the engine light when the car does not enter closed loop. The car is running in closed loop now. I shut off that code before when I was running in open loop all the time.
The obdII readiness monitors will be reset with something as simple as clearing trouble codes. Generally you should follow up with an obdII "drive cycle." This includes specifics like reaching a certain coolant temp, starting and idling then driving car for a specific time, achieving specific speeds anfd holding that speed.
OBDII drive cycle for GM
Read and follow all steps. O2 monitors are referenced in second to last step.
You're in MA, right? Are you woring on an emissions test? Here in NH you're allowed one monitor to be "not ready" without a problem. Looks like the same for MA.
"If a model year 1996 through 2000 vehicle is being tested, it can pass its state inspection with as many as two OBDII monitors “not ready.” If the vehicle is model year 2001 or newer, no more than one monitor may be “not ready” for it to pass. "
MA readiness test fact sheet
HTH
-->Slow
All of the tests were ready yesterday morning and I went and got a sticker in the afternoon. It passed with no problems.
How many drive cycles have to be completed before a test reports as ready? Thanks.
