i m getting ready to tune my car in a month or two and was wondering if their is any fully standalone systems or if its just hptuners, and megasquirt which are piggybacks if im not mistaken, and if so, is their any advantages to them everyone seems to use hptuner. thanks
im not trying to be a smart a$$ but piggy back doesnt replace ecu, standalone is a new ecu so does it work just as good as a standalone
eric mead wrote:im not trying to be a smart a$$ but piggy back doesnt replace ecu, standalone is a new ecu so does it work just as good as a standalone
I think you need to do some research.......... HPT allows us to modify the STOCK computer.... It gives us access and enables us to modify the facotry settings.... Lets say you get one or the other, do you even know what tables and parameters to change and why to change the,??? Im not trying to be a "smartass" myself, just giving you some "food for thought" ...
P&P Tuning
420.5whp / 359.8wtq
I know what a piggyback is, and its definition. You aren't listening to what I'm saying, or you don't know what HPT is. HPT is a way to TURN YOUR STOCK COMPUTER
INTO a STANDALONE. It allows you to edit all the available parameters in the ECU, modify fuel, timing, shifting, fans, anything. It works as good as some standalones, there are some limitations, depending on what car you have. The stock ECU uses an Alpha-N tuning, most boosted applications don't want this, but its not impossible to get a very nice tune with it. For NA, Alpha-N is fine and can yield great results.
yae what are the limitations compared to a standalone i didnt really see anything thats why i was asking and the guy thats probably going to tune my car wanted to know more so thats why im asking. but thanks for your help
Alpha N does work fairly good with centrifugal supercharger setups because the amount of boost per rpm is always consistant and directly porportional, im seeing good results with my tune even though its still needing some work, now turbos i would say are better benifitted by speed density
limitations are things like parameters that you cant change, features that standalones usually have like boost controller/progressive boost/gear based boost/speed based boost/real time tuning, and a bunch of other stuff... if you look up the features of a standalone and then the features of hptuners you should have no problem finding the difference
hptuners guys are always releasing updates for us though, so its pretty cool... im happy with it
Id like to see speed density for the ecotecs, that would rock my world
Rodimus Prime wrote:Id like to see speed density for the ecotecs, that would rock my world
i think my life in general would just be better
Acer wrote:Rodimus Prime wrote:Id like to see speed density for the ecotecs, that would rock my world
As opposed to what?
nothing else is available from GM
All Js are speed density.
sig not found
protomec wrote:Acer wrote:Rodimus Prime wrote:Id like to see speed density for the ecotecs, that would rock my world
As opposed to what?
Consider your life better! MAP/IAT/TPS based fueling is Speed Density, the other option is MAF sensor, which J's don't have, but some of the cobalts do (2.4vvt eco's anyways).
As opposed to what?
lol proto he means instead of tps for load he wants map..
You people are dumb! Fuel control on non-S/C OS's is alpha-n (rpm vs. NOTHING) for fuel delivery making it useless for oh, 10+ psi.
Yes, you can buy _real_ standalones, Haltec, Electromotive, Autronic, Holley, AEM, etc all should work on a 4 banger with a DIS ignition. Megasquirt is kinda difficult to setup for ignition on our cars, but its doable and by the far the cheapest option. Now, 90% of the time, these are wired up as a piggy back, the stock injector drivers are connected to resistors but all sensors are connected, why you may ask, it makes your car run.
