can any one help me with installing my safc on my 03 cavalier
I just hooked mine up like a 2 weeks ago. I have one thing to say and one thing to give you.
It does not work good at all because our cars do not rely on map sensor signal for fuel systems.
Also go to www.ny-jbodies.org then click on library then click onto ecotec pcm wiring diagram if you need more help just let me know.
Project Yellow Blur Is Under Way ! ! ! ! !
Brad Paauw wrote:It does not work good at all because our cars do not rely on map sensor signal for fuel systems.
there is a kpa vs fuel multipler if you look at our map with hptuners... but thats not used under PE which doesnt kick in until 6000-6000RPM but even before then... they are all set to 1.0 stock if i remember correctly....
my 2 cents
