HPT Helper Files (Histograms, Spreadsheets, etc) - Tuning Forum
Friday, June 16, 2006 2:05 PM
Alright, here are some histograms for you guys.
HISTOGRAMS
To Install:
Copy these files to a folder on your hard drive, preferrably in the location where HPT is installed (by default its Program FilesHP TunersVCM Suite 2) then open the Histograms folder, create a new folder, something like "4 Cylinder Histograms", and put these files there. To use them, you must be logging the "vs" values in the table view. You then open the Histogram view, click on a number for the histogram you want to replace, then click the open file button. Select the histogram you want to view. When loaded, right click inside the histogram and select "load all data".
Main Spark Timing Advance
Timing Retard - RPM vs MAP vs Knock Retard
VE Airflow - TPS vs RPM vs VE Airflow (Calculated)
VE Airflow - RPM vs TPS vs O2 mV
VE Airflow - RPM vs TPS vs Wideband AFR (Change wideband sensor for your brand, this is set up for AEM)
SPREADSHEETS
Coming soon...
I will add some more as time goes on. If there are any you would like to contribute, please email them to me through my email.
Edited 5 time(s). Last edited Monday, June 19, 2006 10:38 PM
Re: HPT Helper Files (Histograms, Spreadsheets, et
Friday, June 16, 2006 8:07 PM
This is awesome, I havn't really had the time to sit down and figure these things out yet, but this will definitely help! If you're taking requests I'd love to see one for injector duty cycle.
Friday, June 16, 2006 9:17 PM
word...... since I forgot to save the one the other day you had me do...... lol
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Friday, June 16, 2006 10:59 PM
Ian Brydon wrote:This is awesome, I havn't really had the time to sit down and figure these things out yet, but this will definitely help! If you're taking requests I'd love to see one for injector duty cycle.
What kind of table do you want? RPM vs ???? vs Duty Cycle... need the other item you want to log against... maybe MAP?
Saturday, June 17, 2006 3:37 AM
what can we do with theses files? newbish question i know but is it just a table of your values? or datalogs? i havent seen the hst format anywhere in my adventures with hpt..... any insight would be appreciated
Saturday, June 17, 2006 8:31 AM
Its used in the VCM scanner to analyze the log files.
Saturday, June 17, 2006 6:14 PM
MAP would work, sorry I should have been more specific.
Sunday, June 18, 2006 6:44 PM
so what do you actually do with the VE one, i have a bunch of data here but im not sure what im looking for
Sunday, June 18, 2006 7:20 PM
Yeah I haven't quite worked out what to do with that one, I was trying to find something to tune the VE table with, mostly its to see what the ECU is calculating the VE as in those cells, so you can get an idea of what percentage is what volume of air.
Monday, June 19, 2006 10:11 PM
New VE tuning histograms added.
