Was reading about it, and was curious if anybody here has done it. If so, what type. I'm using at plx devices. with a Bosch LSU4/LSU4.2 Sensor and hope that it will hook up fine.
Nate
1995 Cavalier W/2k1 Engine
yup i did it
its pretty easy actually you tap the white wire 5v output off the wideband controller for the 5v signal which goes in pin 1 (top one) of the HPT box and the ground wire off the wideband controller into pin 5 on the HPT box
Then run the VCM scanner, hit the table icon on the top task bar right click on EID input #1 on the table and select insert and choose wideband from the list and choose plx
Then to show it along with your guages right click add new guage and then select pid, aux list and choose wideband and it will log that and show the guage along with the others, actually i need to get around to posting my guage config file its pretty spiffy
Thanks!
Rodimus, any idea whats up with my wideband values? I hooked it in tonight, analog out to input pin 1 (on top) ground to pin 5 (5th from top)
Its really weird it hardly goes over 11, giving me completely different readings than my 02 guage, I have correct wideband selected,if i choose LM1 it simply does not give any values (as it shoudln't), Im lost, im going to hitup hpt forums tomorrow probabally.
15.149 @ 91.26mph 3-18-2006
innovative has 2 outputs on it, one is a brown, the other a yellow one is a wideband signal the other is a narrowband, you want to get the 5v wideband
I ran into this problem last week with phils, your prob hooked into the narrowband output which is throwing off your values, if you in brown try yellow, if in yellow try brown
Thanks well give it a shot tomorrow and see whats up.
Switched the wires, then on the way to work this morning, Presto!
10.09 wow thats pretty rich there
