EV1 or EV6 - Tuning Forum
EV1 or EV6
Saturday, October 29, 2011 4:49 PM
Does a 2000 LD9 use EV1 or EV6 injectors?
12.6 @ 114.6 MPH
Re: EV1 or EV6
Saturday, October 29, 2011 4:52 PM
neither....it uses mini delphis
Re: EV1 or EV6
Saturday, October 29, 2011 6:36 PM
EvoFire wrote:neither....it uses mini delphis
Yeah, thats right. Thanks. A 96 would use EV1, right?
12.6 @ 114.6 MPH
Re: EV1 or EV6
Sunday, October 30, 2011 12:37 PM
Technically "Delphi" isn't an injector type, its a connector type.
There are two injector types, EV1 and EV6.
There are however 3 injector connector types: Mini Delphi/Multec, USCar, and Minitimer/Jetronix.
There are more than that, however those are the common ones/the J-Body ones.
I'm am nearly positive tho that the LD9 uses the EV1 (fat body) injector type with a Mini Delphi/Multec injector connector type.
Re: EV1 or EV6
Sunday, October 30, 2011 1:16 PM
newt wrote:Technically "Delphi" isn't an injector type, its a connector type.
u are correct in all that u posted Dave.
Re: EV1 or EV6
Tuesday, November 01, 2011 4:54 AM
When you say "fat body" are you referring to the size of the injector? Reason I bring this up is because not all LD9's have the fat injectors I believe. Some have the skinny injectors.
GMR has got nothing on this
Re: EV1 or EV6
Tuesday, November 01, 2011 8:23 AM
00-02 LD9s have the skinny injectors
Re: EV1 or EV6
Wednesday, November 02, 2011 12:15 PM
Yes, the wider injectors are refered to as "fat body" ussually, plastic on the top half, metal on the bottom half, which is EV1.
The skinny injectors are often refered to as "pencil" injectors, they are about the same thickness all the way from tip to tip and have a full plastic body, which is EV6.
My appologies for the LD9 having the EV6 injectors, my Quad 4 knowledge is lacking...haha
Re: EV1 or EV6
Friday, November 04, 2011 7:20 PM
Cool so 00-02 ld9 has ev6
